Enabled 802.1x wired auth on 3750, now can't login
I have a 10/100 3750 used for testing purposes. I enabled wired 802.1x authentication on one port to test - it worked great so I also enabled a guest VLAN and a restricted VLAN on the same port, again with good results.
Previously, I only had a password enabled on the switch since it is a test switch in an isolated environment, "enable password test".
But after my 802.1x testing, I logged out of the switch and tried to log back in, but could not do so remotely - a username and password had been enabled somehow via my commands associated with enabling dot1x. I can direct-connect via a console cable, and use the password "test" to login.
Why did a username and password get enabled for the remote connection? How can I change this back?
