Any extra power supply or power redundancy on cat 2960 switches?
May 25th, 2007
Hi, I need to provide a small, but reliable 1000MB switch to connect two mainframes network adapters (intracommunication).
Since power supplies are a common point of failure in switch, is there anything I could do to offer redundant power supplies on such Catalyst 2960G-8TC switch?
Cisco Catalyst 2960G-8TC Compact Switch
Download Software for this product.
7 Ethernet 10/100/1000 ports and 1 dual-purpose uplink (dual-purpose uplink port has one 10/100/1000 Ethernet port and one SFP-based Gigabit Ethernet port, 1 port active).
LAN base image installed
Compact size and no fan
Magnet included
Order cable guard and rack mount kits separately
Overall Rating: 4 (1 ratings)
ankbhasi Fri, 05/25/2007 - 08:29
Hi Friend,
Cisco RPS 675 and 300 would have been a good option but Catalyst 2960-8TC and 2960G-8TC switches do not have an RPS connector.
About Cisco RPS 675
About Cisco RPS 300
On the other hand these RPS 300 are EOS and RPS 675 will be EOS by October 15, 2007.
*Pls rate all helpfull post
