CallManager Zone Paging
tohoken
Can anyone tell me how to set up CCM 4.1.3 so I can page all phones in my campus at the same time? The page needs to come across their phone speakers.
Brandon Buffin
Callmanager does not have paging functionality built-in. You can use a 3rd party product such as Berbee's Informacast to accomplish this. There are other 3rd party products that do this as well.
www.berbee.com
Hope this helps. If so, please rate the post.
Brandon
Rob Huffman
Hi Ken,
You will need a 3rd party App to accomplish this. I think the consensus would be Berbees Informacast. Have a look;
http://www.berbee.com/public/berbeesoftware/InformaCast.aspx
Hope this helps!
Rob
Not to be redundant but BERBEE would be your best bet :-)
Also, I suggest engaging Berbee Professional Services to help you implement the solution.
Chris
