Backup Config w/ CatTools
May 25th, 2007
we use Kiwi CatTools to backup our network devices.
Does anyone have experience using CatTools to backup the Ironport config?
Ironport is not officially supported by CatTools, but maybe someone has been able to get the config using generic settings?
Thanks in advance!
killerboots_ironport Fri, 05/16/2008 - 15:28
CatTools works, just make sure you keep it from trying to enter enable mode before entering the commands you set. Also if you are trying to enter the command "mailconfig" you may need to enter the send-to email address on the same line as CatTools can't see the reply of the mailconfig command. Do the same thing with the "Y" option to show the passwords in MD5 instead of ****out for portability of the config.
Eisenhafen Thu, 07/24/2008 - 09:50
ironport is now officially supported by CatTools and has been working fine for quite a while.
