Felipe Garrido Fri, 10/15/2010 - 05:58
  • Cisco Employee,
Make sure to issue the create cnf command under telephony-service  after making the change. You'll then need to reset the phone in order for the change to take effect.
-Felipe
ilana_ilana Tue, 11/10/2015 - 11:53
Its been old post, Im wondering, do we have to follow same procedure to capture packets for SIP phones ? or configuration needs to be done under voice register global ?
Felipe Garrido Tue, 11/10/2015 - 12:00
  • Cisco Employee,
Yes, the same process works for SIP phones. Just make sure to issue the "create profile" command under "voice register global" after setting the parameter under "telephony-service"
-Felipe
