try to understand NoNAT
May 25th, 2007
I have a PIX, I want PCs from outside interface to access a server(1.1.1.1) inside. I know I can use static (outside,inside) 1.1.1.1 1.1.1.1 and a ACL to allow.
My question is: can I use NONAT + ACL to do it ?
Overall Rating: 3.5 (2 ratings)
guibarati Fri, 05/25/2007 - 11:49
  • Bronze, 100 points or more
With nonat the Pix will not answare for the "arp requests" sent for the outside IP address. With the static it will!
zulqurnain Sat, 05/26/2007 - 05:00
hello,
outside accessing inside server then it should be
1.1.1.1 = remote host ip address
2.2.2.2 = published ip address
3.3.3.3 = LAN server ip address
static (inside,outside) 2.2.2.2 3.3.3.3 netmask 255.255.255.255
access-list outside_inside permit ip host 1.1.1.1 2.2.2.2
and not static (outside,inside) unless you are planning you change the soure address also
please correct me if i am wrong nonat is used when you want IPSEC traffic to pass through or you don't want any translation to happen on the ip addresses. e.g. VPN tunnels.
HTH, please rate it
