Weird rings on Fax machines w/ VG224 MGCP
May 25th, 2007
Just deployed several VG224s, each with a mix of analog phones and fax machines. The phones work fine, and the fax machines work fine for outbound. However, when the receive a call, something a little strange happens after they pick up on the first ring. I hear 8 low humming noises, which last about 15 seconds. The fax then starts the transmission.
The VG224s run IOS 12.4(7e) w/ MGCP. Fax pass-through is used on the gateways, and we run G.711u accross the board. Config is as follows:
ccm-manager redundant-host 5.6.7.8
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 1.2.3.4
ccm-manager config
mgcp
mgcp call-agent 1.2.3.4 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
The fax machines are Canon 2050P SuperG3
johnnylingo Thu, 05/31/2007 - 22:46
That's great information, but these are on VG224s and I've already configured pass-through with G.711. I'm starting to suspect it's a problem with ECM.
