3660 ROMMON Error
Answered Question
May 25th, 2007
Hello -
Trying to upload a code to a 3660 router via xmodem and after copy the code to the flash, it comes back with an error -
"Erasing flash at 0x30000000sector erase failed at location 0x30000000, status 0x
20202020.
flash sector will NOT erase...aborting"
I have tried it a couple of times and I am out of options. Please advise.
Thank you.
GK
Correct Answer by ankbhasi about 9 years 10 months ago
Hi George,
Happy to know it worked for you.
Now you can erase flash as your router is up with the IOS after the xmodem and then after erase do a copy tftp flash so that image will be loaded on flash as right now it is in DRAM.
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
ankbhasi Fri, 05/25/2007 - 11:03
  • Cisco Employee,
Hi GK,
I believe this is hitting a BUG but before I confirm , do you by any chance have the output of "sh flash all"?
Ankur
Richard Burts Fri, 05/25/2007 - 11:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I would also suggest checking and make sure that the flash is well seated and then try the load again.
Rick
kcgeorge1218 Fri, 05/25/2007 - 11:10
Hi Ankur -
Unfortunately I did not. Any work around this or shd I try a different code ?
Initially, I was trying to TFTP a 12.4T code to the 3660, when that didn't work, I tried the xmodem procedure and that's when I get to see the error.
Thx
GK
ankbhasi Fri, 05/25/2007 - 11:16
  • Cisco Employee,
Hi GK,
If this is the bug which I presume is , give a try with this workaround
Workaround:
1. Boot from IOS image on PCMCIA card
2. Erase flash SIMM
3. Copy IOS image from PCMCIA card to flash SIMM
OR
1. Invoke xmodem with '-r' option so that IOS code is xmodemed into
RAM and executed.
Ankur
kcgeorge1218 Fri, 05/25/2007 - 11:25
Hi Ankur -
I tried the xmodem with the -c option. Would that have made a difference ?
My other option is I have to find another 3660 and try to copy the flash image onto the flash card and try to boot..
ankbhasi Fri, 05/25/2007 - 11:29
  • Cisco Employee,
Hi George,
Can you give xmodem -r a try?
Ankur
ankbhasi Fri, 05/25/2007 - 11:41
  • Cisco Employee,
Hi George,
I don't think so. The problem is with Boot ROM version 12.0(6r)T.
Did xmodem -r option worked for you?
Ankur
kcgeorge1218 Fri, 05/25/2007 - 11:43
Have the xmodem with -r running....shd take another 10 mins.
Correct Answer
ankbhasi Fri, 05/25/2007 - 12:00
  • Cisco Employee,
Hi George,
Ankur
kcgeorge1218 Fri, 05/25/2007 - 12:13
Thx Ankur for the help. Much appreciated.
I had to revert back to the old code, 12.1(5)T12. The 12.4(13b) gives an error when I try to TFTP it. TFTP protocol error - too large to handle.
kcgeorge1218 Fri, 05/25/2007 - 12:18
I know I might be off on a tangent, but is there a way to copy from the DRAM into the NVRAM or flash ?? Just curious. Thx
ankbhasi Fri, 05/25/2007 - 12:23
  • Cisco Employee,
Hi George,
Not that I am aware of but can you confirm which TFTP server you are using which is giving you this error message? Can you try solar winds which works pretty decent for large files.
Alternatively you can give a try using FTP also to copy large file into your flash.
Ankur
