Managment VLAN on a Switch
edw
I'm trying to get a Management Vlan running which isnt VLAN1 due to the secruity issues and best practise.
I have programmed switch as shows:
ip subnet-zero
interface FastEthernet0/1
switchport access vlan 10
interface FastEthernet0/24
switchport mode trunk
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
no ip address
no ip directed-broadcast
no ip route-cache
shutdown
interface VLAN10
no ip route-cache
shutdown
interface VLAN20
ip address 172.30.20.1 255.255.255.0
no ip route-cache
ip default-gateway 172.30.20.25
but I cant ping 172.30.20.1 from my machine. When I move the Manageemtn back to vlan1 I can do this fine. I also cant ping the gateway when I am running management on VLAN20 ??
Any ideas or thoughts ?
Ed
Hi Ed
The pix knows the vlan by the config you assign to the interface ie.
interface ethernet1 100full
interface ethernet1 vlan1 physical
interface ethernet1 vlan2 logical
ethernet1 is the inside interface. The above config says
the physical port is assigned to vlan 1
the logical port is assigned to vlan 2
Now if you want to use vlan 20 as a management vlan for the switch then on the relevant pix interface, and i believe it is a DMZ interface in your case, you will need vlan 20 assigned either as the physical or logical.
So you would have one vlan for the data and one for the management ie your interface config would look like
interface ethernet1 vlan20 physical
where vlan 20 is the management vlan and vlan 2 is the data vlan. You don't have to have them this way round by the way, it could just as easily be
interface ethernet1 vlan2 physical
interface ethernet1 vlan20 logical
Hope this makes sense. I won't be posting for a week or so but hope this solves your problem
Jon
10 Replies 10
ankbhasi
Hi Ed,
I will like to know from where are you trying to ping this switch? I mean your machine is connected to which switch and on which vlan?
If you are not in vlan 20 then do you have any router or switch doing routing between your vlan and vlan 20?
Ankur
Richard Burts
Ed
You have condensed the config in a way that makes it difficult to analyze your problem. You show one switch interface as an access port in VLAN 10, you do not show any switch ports assigned to VLAN 20, and you show a switch port as a trunk.
You have also not told us where your PC is connected or how it is configured (in particular what IP address, mask, and default gateway). You have also not told us what device is doing inter VLAN routing.
Any one of these things could be the issue that is causing the problem. So if you give us more information we might be able to find your problem.
Rick
Rick
Sorry - trying to get out of work;)
My machine is in inside of the interface of a PIX firewall and has static maps for both vlan to the switch. I can ping a machin on the switch on vlan10 and I can also ping 172.30.20.1 when it is assigned to vlan 1 but when I move it to vlan 20 it stop pinging ?? The trunk port is going to the second interface on the firewall.
Basically my question is howcome when I move the management port from vlan1 to vlan 20 I lose this pinging ???
Ed
Just read my last ...
What I'm saying is I can ping the 172.30.20.1 address of the switch when the management vlan is vlan1 bbut when I move that management vlan to 10 I lose it. I'm going through a PIX firewall.
But if we ignore the fact of the PIX and my machine. I lose pinging the PIX interface in the same way. IE I can ping 172.30.20.25 when vlan 1 is management interface but not when vlan 10 is ???
Does that make better sense ?
Ed
Hi Ed
Following on from Rick's post could you just clarify. You talk of the vlan interface being in vlan 10 but your switch config shows the vlan interface being vlan 20.
Yet the only port allocated on your switch is one in vlan 10 ?
Jon
Hiya Jon,
This is following from the post you answered the other day. Its basically about moving the management to another vlan.
The management is on vlan 20 not 10 this was my mistake. So I have tried setting vlan 20 up as a management vlan, yet when this is set as the management one I can't ping the firewall card and I also can't ping from the firewall in. yet if I move the management to vlan 1 its fine. As for vlan 10 - this works fine regardless of which interface is set to management. IE its not affected.
The only port needing configure is port 1 on vlan 10 for test purposes. port 24 is connected to the pix.
So in enssance using the command ping 172.30.20.25 in either situation only gets a response when i have entered:
conf t
int vlan1
management
yet when I then do the commands
conf t
int vlan 20
mangement
I get nothing...... ;(
I am slightly confused as to why I don't get a ping response from the pix card... ?
Now one thought I had in the last 30 mins is do I need to create a logical interface for vlan20 on the pix - at present the gateway is set to the pix physical address, but does the PIX know that its vlan1 and vlan 20 ??? Would this make a difference.
Ed
Ed
I would think that the PIX would need to know that it was trunking and would need a logical interface for VLAN 20.
Also I am not sure that I fully understand what you were saying about changing the management VLAN between VLAN 1 and VLAN 20. You seem to show using the management command to move it. Were you also moving the IP address between VLANs? Perhaps you can be a bit more explicit about all the commands that you are using to make the change.
Rick
Rick
Yes the management command in IOS moves the ip address and shutdown the old interface and start up the new automatically.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/cli/clicmds.html#wp1052840
I now beleive I need to enter vlan20 as the physical interface on the firewall as it isnt understanding the vlan20 tagged packets.
Is this the correct way to change the management vlan by the way ??
Ed
Hi Ed
Jon
Yep tried this yesterday and worked great. I'm assume this is the secure way to do it..
Ed
