05-25-2007 11:10 AM - edited 02-21-2020 01:32 AM
I upgraded our PIX 515E from 7.1 to 7.2.(2) about 6 weeks ago and noticed that it use more RAM, (about 43MB vs 34MB in previous version). After about 3 weeks I noticed i could not access through the ASDM, only telnet. Today the same issue, however this time, no access, telnet, ssh, or ASDM. Also, Cisco clients could not connect, most LAN to LAN vpn's were still up. Any clues as to why this is happening, am I running low on RAM?? After a reboot it works fine. Any help would be grealty appreciated.
PIX 515E
3 interfaces
64MB RAM
IOS 7.2.(2)
CPU rarely goes over 5% and RAM used is usually about 43MB.
Thanks in advance
L. Mace
05-31-2007 11:02 AM
I think that problem could be because PIX amy not be able to handle the VPN load or some VPN client may be sending excessive traffic. The problem also could be because of a faulty RAM module.
06-01-2007 08:36 AM
We are probably going to upgrade the ram to 128 MB.
Thanks for your input.
06-01-2007 08:03 AM
I had similar issue and the problem was related to size of the RAM. I upgraded 64MB to 128MB and the problem gone.
What PIX licence do you have?
Thanks.
06-01-2007 08:35 AM
Ok, I'll probably try a ram upgrade, we were thinking that might be an issue. Your input seems to confirm this.
License inf:
Licensed features for this platform:
Maximum Physical Interfaces : 3
Maximum VLANs : 10
Inside Hosts : Unlimited
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has a Restricted (R) license.
