Low Budget IP Phone Power Cubes
May 25th, 2007
Since I'm trying to build a (cheap as possible) lab environment I'm looking for low budget power cubes for the 7940 IP Phone.
Anyone any idea where to get those? Or can anyone tell me which brand is compatible with cisco's?
Paolo Bevilacqua Sat, 05/26/2007 - 08:37
Lowest price you can find on the the web for compatible power cubes is $14 per unit. It is very very easy to find the vendor using the leading search engine.
