Can not erase ACL line
May 25th, 2007
  • Bronze, 100 points or more
I'm having a problem with an ASA 5510 running version 7.2(2). I see some lines in the inbound and outbound access-list but when I try to erase it it says this line does not exist. I have this problem on ASDM and CLI. Any idea?
zulqurnain Fri, 05/25/2007 - 14:39
hello,
save the config and reboot the FW.
HTH, please rate it
Patrick Iseli Fri, 05/25/2007 - 16:52
  • Gold, 750 points or more
I have the same issue, as allready suggested save the config (wr mem) and reload the firewall.
I will let you know if that solved the issue, but I have to wait a couple of days before I can do the reboot.
sincerely
Patrick
jean.l.pierre Tue, 05/29/2007 - 02:28
Hi!
In CLI mode, what commend do you issue to see the ACL configuration/lines?
JP
