501 open https for external access
Answered Question
May 25th, 2007
I have the following setup;
external ip router (internal ip 192.168.128.1) -----> (external ip pix 501 192.168.128.2) -----> (internal ip pix 501 192.168.1.1)
webserver 192.168.1.2
I'm having difficulty accessing the webserver from the internet. I can access it internally on my network.
Here is the acl lists, can anyone poitn out where I'm going wrong, please.
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 192.168.128.0 router
name 192.168.1.2 owserver
access-list inside_outbound_nat0_acl permit ip any 192.168.1.192 255.255.255.224
access-list outside_cryptomap_dyn_20 permit ip any 192.168.1.192 255.255.255.224
access-list outside_access_in permit tcp router 255.255.255.0 eq www interface outside eq www
access-list outside_access_in permit tcp router 255.255.255.0 eq https host 192.168.128.2 eq https
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface www owserver www netmask 255.255.255.255 0 0
static (inside,outside) tcp 192.168.128.2 https owserver https netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
Many thanks
Suzanne
Correct Answer by acomiskey about 9 years 7 months ago
Check your access list and my post above. You can't refer to the destination in the acl as the inside address(192.168.1.2). The destination is the outside interface.
access-list outside_in permit tcp any interface outside eq www
access-list outside_in permit tcp any interface outside eq https
Overall Rating: 5 (2 ratings)
acomiskey Fri, 05/25/2007 - 12:41
Use the interface keyword like you did in your other static...
static (inside,outside) tcp interface https owserver https netmask 255.255.255.255 0 0
techsitc10 Fri, 05/25/2007 - 13:20
Thanks for the prompt response.
Interestingly, I copied the http rule in the pdm to create the https and so not sure why it changed. I will try re-adding it with the interface keyword and let you know.
Thanks again
Suzanne
techsitc10 Fri, 05/25/2007 - 13:21
Actually the http isn't working either!
Any other ideas ?
Thanks again
Suzanne
acomiskey Fri, 05/25/2007 - 14:16
Suzanne,
192.168.128.2 is not routable on the internet. If that is the address you are attempting to hit from the internet, this explains why it is not working. If you unplugged the inside of the router and plugged a computer directly into outside of pix. Assigned the inside address of the router to your computer, then tried to access 192.168.128.2, then it would work. You most likely will need to access your servers by the outside address of your outside router and create the proper translations in the router as well. Is this the case?
techsitc10 Tue, 05/29/2007 - 06:02
Sorry I should have explained that more fully when I initially posted. There is an external router set up. It has an internal ip address of 192.168.128.1 and has static routes setup to translate through to the static external ip address with a proper internet address on the outside. I just didn't want to publish it unnecessarily.
When I use a computer to connect between the pix and the server it doesn't resolve which is why i think the problem is with the pix and not the router.
Any further help would be appreciated.
Suzanne
acomiskey Tue, 05/29/2007 - 06:10
No problems...
I must have overlooked this before. These acl entries are wrong.
First off, you are limiting the source of the requests to "router" network. I assume you want this to be any instead. Also you have added a source port "router 255.255.255.0 eq https", which the requests would never have. They would be some random port above 1024. So the statements should look like this.
access-list outside_access_in permit tcp any interface outside eq www
access-list outside_access_in permit tcp any interface outside eq https
techsitc10 Fri, 06/08/2007 - 04:44
Sorry for the delay in the reply lots of things going on at the moment.
I've tried this and got a null rule message.
It still doesn't work.
Anything else I'm missing ?
Suzanne
acomiskey Fri, 06/08/2007 - 04:49
Could you post the relevant config so we can see what's going on?
techsitc10 Fri, 06/08/2007 - 04:55
You're amazingly prompt at replying. i will do, at present I'm at another site so it will be next week now but I'll update then.
Thanks for all your help.
Suzanne
techsitc10 Thu, 06/21/2007 - 12:31
acomis apologies for the delay
I've added these and this is my current config
Building configuration...
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
domain-name ciscopix.com
names
access-list outside_in permit icmp any host 192.168.128.2 echo-reply
access-list outside_in permit tcp any host 192.168.1.2 eq www
access-list outside_in permit tcp any host 192.168.1.2 eq https
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.1.2 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
static (inside,outside) tcp interface www 192.168.1.2 www netmask 255.255.255.255 0 0
static (inside,outside) tcp interface https 192.168.1.2 https netmask 255.255.255.255 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.129 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxx
: end
Correct Answer
acomiskey Thu, 06/21/2007 - 12:44
techsitc10 Thu, 06/21/2007 - 13:00
THanks for bearing with me..
I thought that was what I had added, but just re done it and it works fine.
Thanks again for all your help and your extra prompt replies.
