Equipment used in CCIE R&S hands-on test?
May 25th, 2007
I am gearing up for my CCIE R&S test. The Cisco website lists a 3275 and 3825 router and a Catalyst 3550 and 3560 as being used for the hands-on test. It does not say how many of each type are used.
Is it possible to inform me of how many routers and switches I will require to throughly practice? If not, would you mind pointing me in the appropriate direction for getting the best possible setup for testing the test?
Thank you.
srue Mon, 05/28/2007 - 05:10
  • Blue, 1500 points or more
If you're using one of the CCIE prep lab workbooks, follow their lab layout.
