How would I create this report?
May 25th, 2007
Using 5.1 - I need to create a report that shows top 10 outbound (external) e-mail domains just like you see when you use Outgoing Mail Delivery and sort by domain in the Monitor Tab.
Reports section only seems to have summary type stuff.
I used to be able to do this with mail flow but no more with v5.
thx
usommer_ironport Tue, 05/29/2007 - 12:14
thx
take a look at the free spamtowho utility from the support webpage.
It allows very detailed custom reports based on the mail-log files.
regards
Uwe Sommer
