question regarding easy vpn server
May 26th, 2007
Lets say i connect with my easy vpn client, to my workplace, where we have easy vpn server.Is there a way to use the internet from my work place, with my easy vpn client?
From what i know, with easy vpn server you can protect traffic to some subnets (lets say from the workplace), but i'm not sure if you can access the internet.
My setup: easy vpn server. On that router i have a default route to provider.
When i connect with my client from home, i know the office router automatically puts a static route to me, so why can't i access the internet at my workplace with this setup?
Thank you very much for your time.
Best Regards,
thult Mon, 05/28/2007 - 03:26
You have to configure split tunneling rules on the easy VPN server that will be used by your Easy VPN client.
