IPPCX 4.5 with CCM 5.x
May 26th, 2007
is there any way to install the IPCCX 4.5 standard in the same server of CCM 5.x ,If this is possible plz provide a link .
Also is it possible to install IPCCX 4.5 with unity server (7815-with win 2000) in the same platform
Overall Rating: 4 (1 ratings)
lpezj Sat, 05/26/2007 - 06:56
  • Gold, 750 points or more
IPCCX 4.5 is a Windows based platform. CCM 5.X is a Linex based platform, so it is no possible to install in the same hardware.
I have never installed the IPCCX and Unity in the same platform. You can try it.
Hope this helps,
Juan Luis
Chris Deren Sat, 05/26/2007 - 07:33
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Absolutely, simply create call handlers and map caller input digits to other call handlers/director handlers, etc.
HTH,
Chris
lpezj Sat, 05/26/2007 - 07:48
Only one thing, regarding IPCCX and Unity installation in the same machine, you must try to do it, but not for a production system, obviosly. It is not a supported configuration by Cisco.
Juan Luis
