ATOM Cisco 7206VXR (NPE-G2)
May 26th, 2007
I try to configure ATOM in two 7206VXR (NPE-G2) routers as the following
-first router
interface ATM2/0.100 point-to-point
no snmp trap link-status
pvc 0/1234 l2transport
xconnect 10.1.1.1 50 encapsulation mpls
-second router
xconnect 10.1.1.2 50 encapsulation mpls
But vc is down
Local intf Local circuit Dest address VC ID Status
AT2/0.100 ATM AAL5 0/100 10.1.1.1 50 DOWN
I need to know if 7206VXR (NPE-G2) support ATOM configuration or not
PE#show ver
Cisco IOS Software, 7200 Software (C7200P-ADVIPSERVICESK9-M), Version 12.4(11)T1, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 25-Jan-07 20:33 by prod_rel_team
ROM: System Bootstrap, Version 12.4(4r)XD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD2, RELEASE SOFTWARE (fc2)
Suez_PE uptime is 1 week, 3 days, 5 minutes
System returned to ROM by reload at 11:20:47 CAI Wed May 16 2007
System restarted at 19:29:04 CAI Wed May 16 2007
System image file is "disk2:c7200p-advipservicesk9-mz.124-11.T1.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 35245323
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.1
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 90 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 270 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2 Serial interfaces
2 ATM interfaces
2045K bytes of NVRAM.
500472K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
mrcomm2000 Sun, 05/27/2007 - 05:47
Dear mohhamed
I made the same configuration in 2 routers Cisco 7206VXR (NPE-G1) with IOS c7200-js-mz.123-8.T5.bin and vc is up
AT1/0.300 ATM AAL5 2/300 10.1.1.3 300 UP
Please advice
thank you
Paolo Bevilacqua Sun, 05/27/2007 - 08:41
If same configuration fails on the newer IOS/NPE, suggest you contact the TAC for the due support.
Rahul Kachalia Sun, 05/27/2007 - 12:55
If possible pls provide output of following cmds:
s int at2/0
s mpls l2 vc det
s mpls int
s mpls ldp neighbor
s ip route 10.1.1.1
s ip route 10.1.1.2
thanks,
rahul.
