PIX 501 6.1(4) upgrade
franzsyntax
Hi there. Is there anyway to get a hold of newer software than the 6.1 with my normal private lowlevel account here? Also i'd like the newer version of PDm, as i am running the 1.1 version
Thax
5 Replies 5
pmccubbin
Level 5
Level 5
The Pix 501 won't run anything above 6.x software even if you did have a valid contract with Cisco.
Hope this helps.
So if i understand you correct, i should be able to upgrade to v 6.2 or higher, but am not able to because i don't have a contract with cisco.
Is that correct?
Anyway, thanx for the very wuick reply
Yes, you need a Cisco contract and your PIX 501 requires a minimum of 8 MB Flash and 16 MB RAM to upgrade to 6.2 or higher.
Hope that helps.
Thanx, you have helped a lot.
Wonder if i could bother you just a bit more :-)
How do i make a access-list, hint, opening ouside ports to access internal IP addresses and ports? I have a server running, and need to open some ports for it. I got the rest working, so now i can access internet via PIX. My old router is almost dead:-) And i only want to use the PIX 501 as a router.
Heeeyyy, need to highlite my problem a bit.
A have read a lot of articles here on the forum, but i think i am to dumb :-)
Could you please type an example of how to open the port 10000 from ip 192.168.2.105 to 192.168.1.2 from the outside to inside. With everything involved, the examples i found missed some parameters, and i could not get it to work.
Youre the man.
Kind regards, Franz
