SHOW CONTROLLERS COMMAND
Answered Question
May 26th, 2007
When I run a show controllers command I get the following....
HD unit 0, idb = 0x29A82C, driver structure at 0x2A1DF0
buffer size 1524 HD unit 0, V.35 DCE cable, clockrate 64000
AND
HD unit 1, idb = 0x2A7680, driver structure at 0x2AEC40
buffer size 1524 HD unit 1, V.35 DTE cable
Of course much is ommited. I only want the info of DTE or DCE calbleing.
Is the HD 0 the serial 0 and HD 1 the serial 1?
If not what are the HD's?
Is there a better command to find DTE or DCE?
Correct Answer by Paolo Bevilacqua about 9 years 8 months ago
This is the only command to know what type of cable is attached, and yes 0 and 1 are the serial ports.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Sat, 05/26/2007 - 15:33
