NDR in Unity4.2(1)
Hi All..
Just to check, Is there anyway in Unity4.2(1) to prevent internal callers from leaving voicemail as well when the other party's mailbox is full? If not, is there anyway that the NDR can have any indicators so as to inform me of unsuccessful delivery instead of me loggin in and check. As the NDRs are taking up my mail space.
Rgds
neesharm Sun, 05/27/2007 - 23:21
  • Bronze, 100 points or more
when you go to your Unity server desktop > open the "Unity Tools Depot" >
expand the "Administration Tools" folder > double-click on the
"Advanced Settings Tool" and what are the values set for the following attributes:
"Conversation - Full Mailbox Check Feature"
"Conversation - Full Mailbox Check Prompt"
Also do you have following registry
HKLM\Software\Active Voice\MalEx\1.0\DisableStatusCheck
If yes whats the value its set to ?
neesharm Sun, 05/27/2007 - 23:30
I am looking into a few bug ...however can you verfiy if the "mailbox is actually full" or is it an incorretc warning ?
setonhnet Fri, 06/01/2007 - 07:49
I'm experiencing the same problem. Internal callers don't get the prompted message that he mailbox is full, but callers from outside do.
