Richard Burts Tue, 05/29/2007 - 06:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
upendra
Amit has made a suggestion about using an access list applied to the vty lines with access-class and specifying the log parameter in the access list as one way to do what you want. Depending on the version of code that you are running there may be a better option. It was introduced in 12.3T, made available in 12.2S, and incorporated into 12.4. It is enhancements to the login process and allows you to create a syslog record for every successful login (and for every unsuccessful login attempt if you wish). This link will give you more information about this new feature:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123t/123t_4/gt_login.htm
Rick
