IPs address problem
May 27th, 2007
Few of the IPs are unable to access external resources where as it is working fine on LAN and when trying to access any of the external Server it is getting stop at the gateway. The network is flat there is no VLans configure neither Access list is there. Please provide me the solution to allow access to external resources. When try to ping with this problem ip to any of the external resouce it is stopping at the gateway.
Overall Rating: 3 (2 ratings)
mohammedmahmoud Sun, 05/27/2007 - 04:40
  • Green, 3000 points or more
Hi Mohammed,
Most probably there is NAT configuration on your gateway which might have problems, can you please confirm, and if yes can you please post the NAT config ?
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
minumathur Sun, 05/27/2007 - 06:28
  • Bronze, 100 points or more
As per your requirement , NAT is best solution, I have attached simple NAT document for your ref,
