"voice-class aaa" on pots dial-peer?
May 27th, 2007
I have created two groups, the DEF and the ALTG. ALTG is in voice class aaa 1. The ALTG says "none" for all methods and the DEF says "stop-only" accounting, aaa authentication login h323 and aaa authorization exec h323. This means DEF will send STOP accounting and is associated with the RADIUS server and ALTG does not send any radius messages. Marking voip dial-peer with "voice-class aaa 1" so that it will use the methods from ALTG group suppresses AAA perfectly, BUT for some reason it does not work for pots dial-peers. Is it a known limitation?
