Can't get ip for Vista
May 27th, 2007
I use C2801 router with IOS 12.4T advservice for DHCP server,and connect with MS Vista, but it can't get ip, but use XP and win98 is ok, so, please help!!
Thanks !
Jagdeep Gambhir Mon, 05/28/2007 - 05:47
  • Red, 2250 points or more
There should not be any issue with Vista, in getting IP address from DHCP. Please make sure that internal firewall is disabled and NIC is configured properly.
thkoo Thu, 05/31/2007 - 20:26
thanks for ur help, but even I disable
the FW function in Vista, still can't get ip,
so, have any suggestion ?
thanks !!
jesusdamian Fri, 06/01/2007 - 07:02
can you connect to network resources if you assign a static IP to the Vista machine?
I dont see how the Vista machine is not able to obtain an IP.
what about the NIC settings? Instead of auto negotiate duplex and speed, force 100/Full, or whatever settings you are using.
also, try updating the NIC drivers on the Vista machine.
thkoo Tue, 06/05/2007 - 17:50
Thanks for your help, I try to hard code thr ip address to Vista, it can connect to the network, but use DHCP from C2801 router is not.
For router , when I use "show ip dhcp binging' command, it seem had give the ip
to the Vista.
I had try 4 Vista pc, the symptom is same.
regards,
Koo
anandramapathy Tue, 06/05/2007 - 20:03
  • Bronze, 100 points or more
is the vista machine on the same vlan as the DHCP server ?
anandramapathy Tue, 06/05/2007 - 20:04
Try connecting an ethereal on the same vlan as the Vista machine & do a acapture
