WAN serial Interface configuration with eigrp
Answered Question
May 27th, 2007
Hi all,
I have cisco 1800 series router ,we need to configure 3 serial (v.35 ) input each of 2mbps data coming from service provider to configure to use 6 mbps circuit , and the routing on eigrp to connect two branch offices, Can anyone help out , how to do this, and if anything to be cautioned ! , thank you . Amrendra.
Correct Answer by Anand Narayana about 10 years 1 month ago
Hi Amrendra,
i was assumed by question that you required point-to-point link will be connecting to your end from 3 different service providers at a 2 Mbps bandwidth, if that is the case, find the working configuration below.
multilink virtual-template 1
interface Virtual-Template1
ip unnumbered FastEthernet0
ppp multilink
interface Serial0/0
bandwidth 2048
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1
bandwidth 2048
no ip address
encapsulation ppp
ppp multilink
interface Serial1/1
bandwidth 2048
no ip address
encapsulation ppp
ppp multilink
interface FastEthernet0
Not necessarily eigrp is required, but if this router is going to advertise to different routers different network, then you need.
router eigrp 4444
network 192.168.1.0
network 10.0.0.0 (optional) for advertising diff network router)
for verifying the bandwidth virtual 6 Mbps, then you need to type "show virtual-access 0" or 1, once if you find that it shows 6 Mbps then your done.
i hope your are clear with this.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sun, 05/27/2007 - 19:48
  • Hall of Fame,
    Founding Member
you can optionally use MLPPP to aggregate the links together, if you don't do that the links will will balance anyway with the CEF algorithm . There is nothing special about the eigrp configuration in this case.
Correct Answer
Anand Narayana Sun, 05/27/2007 - 22:57
  • Silver, 250 points or more
Hi Amrendra,
ppp multilink
interface Serial0/0
bandwidth 2048
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1
bandwidth 2048
no ip address
encapsulation ppp
ppp multilink
interface Serial1/1
bandwidth 2048
no ip address
encapsulation ppp
ppp multilink
router eigrp 4444
network 192.168.1.0
amrendraks Sun, 05/27/2007 - 23:09
SUPERB !!! Mr Anandnarayana,
Thank you very much It made everything clear.
Thanks again.
paolo bevilacqua Mon, 05/28/2007 - 09:46
  • Hall of Fame,
    Founding Member
Sorry, it totally escapes to me how ppp multilink could work when terminated on different routers ISP side, or worst, different ISP !!!
amrendraks Tue, 05/29/2007 - 00:25
Hi bevilacqua,
Actually I have single isp, and link aggregation was required for me so it worked well, In fact I was not aware of how to do, So I got the point and did the said way, but Mr Anandnarayana thought the links are coming from different ISPs are incorrect.
I appreciate the method os ppp multilink you suggested but I was looking for some technical steps too.
