Warning message
what is virtual template interface
May 28th, 2007
hi all
Please explain me what is vitual template interface and when should used.how can someone used it to bind physical intfaces under virtual templte int?
Overall Rating: 4.2 (5 ratings)
Anand Narayana Mon, 05/28/2007 - 02:27
  • Silver, 250 points or more
Hi San,
virtual template interface are used to combine multiple interfaces in to one virtual interface called virtual template, assume that you have you hav two 2 Mbps link & you wanted to combine in to 1 virtual link as 4 Mbps, virtual interface will do the needful, go through the configuration below, which is working configuration, which i hav already posted today.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40.1dde9f4b/1#selected_message
mohammedmahmoud Mon, 05/28/2007 - 03:08
  • Green, 3000 points or more
A virtual template interface is used to provide the configuration for dynamically created Virtual-Access interfaces. It is created by users and can be saved in nonvolatile RAM (NVRAM).
Once the virtual template interface is created, it can be configured in the same way as a serial interface.
To create a virtual template interface that can be configured and applied dynamically in creating virtual access interfaces, use the interface virtual-template command in global configuration mode.
Virtual template interfaces can be created and applied by various applications such as Virtual Profiles, virtual private dialup networks (VPDN), PPP over ATM, PPP over Frame Relay, protocol translation, and Multichassis Multilink PPP (MMP).
Following are FR and ATM examples:
interface Serial1/0.1 point-to-point
bandwidth 128
frame-relay interface-dlci 51 ppp Virtual-Template1
class FRTS
interface ATM1/0.52 point-to-point
ip vrf forwarding customer
pvc 101/52
abr 167 167
oam-pvc manage
encapsulation aal5ciscoppp virtual-Template 1
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_command_reference_chapter09186a0080080d36.html#wp1017915
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
san_dec21 Mon, 05/28/2007 - 22:36
but what is difference between virtual template int and multilink int
Anand Narayana Mon, 05/28/2007 - 23:18
Hi San,
A Virtual Template Interface Service feature provides a generic service that can be used to apply predefined interface configurations (virtual template interfaces) in creating and freeing virtual access interfaces dynamically, as needed.
A virtual template interface is a logical entity?a configuration for a serial-interface but not tied to a physical interface?that can be applied dynamically as needed. Virtual access interfaces are virtual interfaces that are created, configured dynamically (for example, by applying [cloning] a virtual template interface), used, and then freed when no longer needed.
mohammedmahmoud Tue, 05/29/2007 - 04:18
The Multilink interface was introduced in Cisco IOS Software Release 12.0(3)T.
A multilink group interface is a collection of interfaces bundled together in the multilink PPP configuration, accordingly with a multilink group interface, you can bundle interfaces into logical multilink groups.
Multilink interface supports only PPP encapsulation.
Mohammed Mahmoud.
radwango1 Tue, 09/30/2014 - 08:04
when I give  inside Virtual Template this command it gives me error, (PPP Multilink)
this is the error message
DWNLD_TO_CPP_FAILED: F0: fman_fp_image:
MLP bundle  download to CPP failed
any idea ?
