6513 Etherchannel at different speeds
Answered Question
May 28th, 2007
I have a customer who wants to connect 2 switchs 6513.
He wants to create an Etherchannel with 2 link in 10Gigabit on a module, and connect a second Etherchannel with 4 links in Gigabit on an other module.
My question is: is it possible ton mixed those 6 links in the same Port-channel? or is it imcompatible because of the different speeds (10giga and giga).
Correct Answer by Amit Singh about 9 years 11 months ago
In addition to Mahmmod's post, I would suggest to create the 2 ether-channels as Layer3 etherchannels.Run Static routing or routing protocol, and the routing protocl will carry to two different path, which will give you load-balancing accross the channels and also the fail-over links with out any service disruption.
HTH,Please rate if it does.
-amit singh
Overall Rating: 3.3 (4 ratings)
Amit Singh Mon, 05/28/2007 - 03:52
  • Cisco Employee,
You can't use port with different speeds in the ether-channel , either all has to run 1 gig or 10 gig .
It is unsupported because you just making all these individual links into one logical bundle , all should have similar capabilities in order to work as one logical connection .
I have tried the same and found out that either the 10G ports works in a bundle or 1G ports but not all of them simulatneously.
HTH,Pleae rate if it does.
-amit singh
croue Mon, 05/28/2007 - 04:40
Thanks for your response.
And how do we choose between the 10Giga and Giga Etherchannel?
Because the customer wants to use the four Gigabit Etherchannel ports in backup of the 10Giga ehterchannel
mahmoodmkl Mon, 05/28/2007 - 04:49
  • Gold, 750 points or more
In this case u need to create 2 ether-channel groups combining u r gig and 10 gig interfaces seprately.If this two ether-channels are going to connect to the same switch at the other end then i think STP will come in to picture,blocking one of ur link.
Mahmood
Correct Answer
Amit Singh Mon, 05/28/2007 - 07:16
  • Cisco Employee,
-amit singh
