CSCsi25051 Bug
May 28th, 2007
  • Bronze, 100 points or more
Does anyone have a workaround , or another ios that works ?
"packets get process switched instead of fast switched when
testing IKE/IPSEC. "
We're running c870-adventerprisek9-mz.124-9.T1.bin, and I can't se that packets are cef switched.
BR,
Bjornarsb
paolo bevilacqua Mon, 05/28/2007 - 07:06
  • Hall of Fame,
    Founding Member
The bug seems to be recent and has been assigned already. It should not impact practical operation of the router, but if you want a more expeditious solution, open a TAC case and ask the engineer to link your case against this bug.
