How to clear dsl counters?
May 28th, 2007
Hi I'm troubleshooting an atm/dsl interface on a 877 router. We have some problem whit CRC errors and Header errors. My problem is that I want to clear the counters(errors when "show dsl int atm 0"),
I have tried:
clear atm
clear int atm 0
clear counters atm
But nothing seems to work, is there another way to clear these counters.
Overall Rating: 3 (2 ratings)
mohammedmahmoud Mon, 05/28/2007 - 05:46
  • Green, 3000 points or more
"clear counters atm 0" should do it.
If there is no problem in clearing all the counters on the router do "clear counters" and it should clear all your counters.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
lamin.sonko Mon, 05/28/2007 - 05:54
tried clear counter atm 0.
this clears only atm interface. I want to clear the information shown when command "sh dsl int atm 0". This is high-level DSL port information.
/ Lamin
mohammedmahmoud Mon, 05/28/2007 - 06:00
As i told you before, if there is no problem in clearing all the counters on the router do "clear counters" and it should clear all your counters.
Mohammed Mahmoud.
goldk28611 Sun, 03/02/2014 - 03:45
Any good advise on the original question?
"clear counters" doesn't clear the stats when doing the command: show dsl int atm 0 which is what was originally asked. Clear counters only clears interface stats
Serge Amos Sun, 03/02/2014 - 09:06
Only a reload will clear these counters.
