Minimum memory requirements.
Answered Question
May 28th, 2007
Which are the minimum memory requirements for a router running OSPF in a WAN consisting of 45 of them?
Correct Answer by Amit Singh about 9 years 11 months ago
Well, it depends on how big the routing table is.It also depends on the type of OSPF design you are making. For example if you have using the hierarchical design using the areas then Stub area or totally stub area routers dont need high memory on them. I would look atleast 128MB DRAM on the routers to run OSPF and other services on it.
http://www.cisco.com/en/US/tech/tk365/tk480/tsd_technology_support_sub-protocol_home.html
HTH,Please rate if it does.
-amit singh
Overall Rating: 4 (1 ratings)
Correct Answer
Amit Singh Mon, 05/28/2007 - 07:21
  • Cisco Employee,
-amit singh
