Trunking vlan filtering
Overall Rating: 5 (1 ratings)
Amit Singh Mon, 05/28/2007 - 08:37
  • Cisco Employee,
You can only use" switchport trunk allowed vlan "command to achieve the same. You need a combination of switchport allowed/remove commands only when you want to remove some of the vlans from the trunk and allow some of the vlans simultaneously.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2960/12225see/cr/cli3.htm#wp1948736
HTH,please rate if it does.
-amit singh
Amit Singh Mon, 05/28/2007 - 09:09
  • Cisco Employee,
Native vlan is enabled on Cisco switches by default and Vlan1 is the native vlan. The native vlan is used to carry untagged frames across a trunk link.You will not be able to form a trunk if the native vlan is different on the trunk links. They have to be same on both the sides.
-amit singh
ankbhasi Mon, 05/28/2007 - 08:39
  • Cisco Employee,
Hi Friend,
On IOS switches if you just allow vlans that will take care of your requirement and no need to specifically clear other vlans first
Switch#sh run int gig1/0/23
Building configuration...
Current configuration : 137 bytes
interface GigabitEthernet1/0/23
switchport trunk allowed vlan 22-26
switchport mode trunk
end
Switch#sh int gig1/0/23 switchport
Ankur_Desk_Switch#sh int gig1/0/23 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: 22-26 <<<---------
Ankur
*Pls rate all helpfull post
s.arunkumar Mon, 05/28/2007 - 22:21
  • Bronze, 100 points or more
afaik, vlan 1 is management vlan and native vlan by default.
yes all the ports are in vlan 1 by default
in trunking if isl method is used then native vlan need not to be same.(and cisco s/w by default uses isl)
but with 802.1q trunking the native vlan packs as send untagged.so its a must that native vlan on both end be the same...
regards
arun:)
