Configuring Prior Used 831 ADSL Router to Just Connect to Internet
May 28th, 2007
Have a Cisco 831 DSL router pulled from working environment. I've tried a number of CLI entries to get the router to simply connect to the Internet with no success. At one point, I could ping Internet provider gateway and DNS server. I know more than what "not being able to connect" implies-yet I obviously am overlooking a simple matter. Getting the router back to how they are shipped new for CRWS (web setup) is fine with me. I can build on that. Following is running-config, sh version, and proof that web setup files are all present in webflash. I have stripped this running-config to nothing except an ethernet address to be able to communicate with the router over IP on my LAN. The DSL information is as follows:
I switch the Embarq DSL modem to run as a bridge. IP addresses are assigned via DHCP. Modem is running what appears to be proprietary encapsulation ENET ENCAP. (I've never switched this to RFC 1438 yet, when trying to set up router.) Multiplex is LLC, VPI 8 and VCI 35, ATM QoS Type UBR
Building configuration...
Current configuration : 931 bytes
version 12.4
no service pad
hostname Router
memory-size iomem 5
no aaa new-model
resource policy
ip subnet-zero
no ip dhcp use vrf connected
ip cef
no ip ips deny-action ips-interface
interface Ethernet0
ip address
interface Ethernet1
no ip address
duplex auto
interface Ethernet2
no ip address
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
ip classless
ip http server
no ip http secure-server
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 120 0
length 0
scheduler max-task-time 5000
Router#sh version
Cisco IOS Software, C831 Software (C831-K9O3SY6-M), Version 12.4(2)T4, RELEASE SOFTWARE (fc2)
Technical Support:
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 01-Mar-06 10:58 by ccai
ROM: System Bootstrap, Version 12.2(8r)YN, RELEASE SOFTWARE (fc1)
Router uptime is 23 minutes
System image file is "flash:c831-k9o3sy6-mz.124-2.T4.bin"
Cisco C831 (MPC857DSL) processor (revision 0x400) with 46695K/2457K bytes of memory.
Processor board ID AMB08250J5J (1968708112), with hardware revision 0000
CPU rev number 7
3 Ethernet interfaces
4 FastEthernet interfaces
128K bytes of NVRAM.
12288K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Router#sh webflash
Web flash directory:
File Length Name/status
1 986 ConfigExp.cfg
2 474217 CRWSbHlp.html
3 941455 CRWS_1.jar
4 278042 CRWS_2.jar
5 62561 CRWS_VPNLogin.jar
6 47026 GUI.html
7 4895 home.html
9 3463 VPNLogin.html
[1821320 bytes used, 13684 available, 1835004 total]
bjornarsb Tue, 05/29/2007 - 00:20
Try this:
interface Ethernet1
bandwidth 2048
ip address dhcp
ip access-group 115 in
no ip proxy-arp
ip nat outside
ip route-cache flow
service-policy output QUEUING
interface Ethernet0
ip address 192.168.X:X secondary
ip address 172.16.X:X
ip accounting output-packets
ip nat inside
ip route-cache flow
standby ip 192.168.X.X
standby preempt
hold-queue 100 out
ip nat inside source list 5 interface Ethernet1 overload
access-list 5 permit
If it does not work try:
debug dhcp
(ter mon)
to see if you get an IP from the ISP
