How to save the startup-config file of 3560 onto my PC?
shuangufl
I connect my PC to the switch 3560 through the console port, how can I save the startup-config file onto my PC? Is there some specific command? Thanks a lot!
2 Accepted Solutions
mahmoodmkl
Level 7
Level 7
U need to have tftp server on the pc,and it should have IP connectivity with the switch.
if u have this things then login in to the switch and enter the below commands.
switch#copy startup-config tftp
Mahmood
Using console port, I guess you are using Hyper Terminal then there are 2 different ways to copy the contents of Startup-Config.
Issue command Show Startup-config
then select the config lines and paste into a text editor and save as text file or wordpad.
the second option is select from the Hyper Terminal Menu Transfer --> Capture Text
then specify a filename and path where you want to save this and click Start
Then Issue Show startup-config
then again transfer --> capture text --> stop
you will find the output of show startup-config is saved into the file you specified.
I think there is a 3rd way which is by using xmodem receive file option.
The best option will always be to use a tftp server running on your pc via the LAN connection.
Shaheen
mahmoodmkl
Level 7
Level 7
Mahmood
Shaheen
glen.grant
If you are using something like Tera Term as your client just turn on the logging feature , on the switch issue "term length 0" then do a show runn command and this will runn the config into the log. Close the log window and it will ask you where you want to save it , just choose and this will save as a text file . most terminal emulators have some form of logging feature.
anharring
Learn to use the TFTP server method.
Cisco suggests this TFTP product that can transfer more than 32M and is also a syslog server:
http://tftpd32.jounin.net
You can not TFTP via a console cable so you need an ethernet connection.
The easiest way to copy stuff is via TeraTerm and its log facility:
http://www.ayera.com/teraterm/
Much better than HyperTerm.
