Help....Mixed up with NAT Translations
May 28th, 2007
Hi All,
Im new here.... i have CCNA knowledge and im rather new to firewalls.
My new workplace has a 515 installed, so i started reading about PIXs to see whats going on !!!
in the configuration i have 'nherited' i have the following lines about NAT
global (outside) 1 interface
global (DMZ-Database) 1 interface
global (DMZ-App) 1 interface
nat (inside) 0 access-list IN-OUT-NONAT
nat (DMZ-Database) 0 access-list DMZ-DAT-NONAT
nat (DMZ-App) 0 access-list DMZ-APP-NONAT
From studying i realize that whoever did the conifuration used the NAT command and the identifier (0) to specify that he DOES NOT WANT NAT Translation ...RIGHT ???
Now, in his GLOBAL commands he specifies the outbound interfaces that have to use the interface IP Address ??? Am I correct ???
If i am correct in both cases then isnt this a clashing issue...
he first specifies that he does not wish any NAT translations, and then he specifies that the outbound traffic to (outside), (DMZ-Database),(DMZ-App) must use that interface's IP Address !!!!
Am i missing something here ???
Please note that all the access-lists which are used int eh NAT commands all specify PERMIT IP ANY ANY !!!!
Thanks in advance,
George
zulqurnain Tue, 05/29/2007 - 00:45
  • Bronze, 100 points or more
for your question:
1. Yes u r correct the ip address used will be of the 1 interface.
on the other hand for your query:
the last admin from whom you inherited wanted:
1. to not to preform any natting / translation on traffic moving from inside to DMZ's.
2. but to perform natting translation on traffic moving from inside or DMZ's to outisde.
hence looking at the configuration, traffic moving between inside and DMZ's will not be natted at all, but traffic moving outside from inside or from DMZ's to outside will be natted taking the 1 interface ip address.
HTH, please rate it
jean.l.pierre Tue, 05/29/2007 - 02:25
Hi!
I think in order to know if tha traffic is beeing natted or not, you have to paste here the 3 ACLS configured on the NAT statements.
JP
g-serghiou Tue, 05/29/2007 - 02:31
ok, here they are:
access-list outside extended permit ip any any
access-list IN-OUT-NONAT extended permit ip 10.154.11.0 255.255.255.0 10.154.0.0
255.255.0.0
access-list IN-OUT-NONAT extended permit ip 10.154.11.0 255.255.255.0 10.189.0.0
255.255.0.0
access-list DMZ-APP-NONAT extended permit ip 10.154.32.0 255.255.255.0 10.154.0.
0 255.255.0.0
access-list DMZ-DAT-NONAT extended permit ip 10.154.42.0 255.255.255.0 10.154.0.
0 255.255.0.0
access-list DMZ-1 extended permit ip any any
access-list DMZ-2 extended permit ip any any
access-list INSIDE extended permit ip any any
I got the reply previously that NAT(PAT) only happens when talking via the outside interface (EDITED: or more correctly, not using NAT for any ip address not specified in the Access-lists in the NAT statements)!!!
i think what confuses me is the usage of (0) in NAT to specify that no NAT is wanted, and then the (1) in GLOBAL command... what is the actual meaning of these numbers-identifiers and what is their exact relation ????
i had the impression, from reading books on PIX configuration that these numbers go hand-in-hand....obviously they don't ???
George
acomiskey Tue, 05/29/2007 - 04:50
  • Green, 3000 points or more
The numbers are related in global and nat statements.
nat (inside) 1 0.0.0.0 0.0.0.0
jean.l.pierre Tue, 05/29/2007 - 05:23
Hi!
They are related (global and nat identifiers). The only exception is the NAT 0.
Can you paste here the configuration of the PIX interfaces?
JP
g-serghiou Tue, 05/29/2007 - 20:33
Hi JP.
Here is thh config of the Firewall !!!
im just puzzled as to when u can use different numbers(identifiers) for NAT and GLOBAL. Does't the Global identifier need to be specified in a NAT statement !!!! Should the configuration have a NAT with id 1 in addition to 0, so that traffic within DMZs does not get NATed, and to be NATed when going to oustide ????
anyway, here is the config. also you can see that they are using a firewall....but they pemit ALL on all !!! EVEN FROM OUTSIDE !!!! :)
PIX Version 7.2(2)
PIX-515
enable password mF9rSbz4w8A4m2vX encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address 10.154.10.1 255.255.255.252
interface Ethernet1
nameif inside
security-level 100
ip address 10.154.11.250 255.255.255.0
interface Ethernet2
nameif DMZ-App
security-level 100
ip address 10.154.32.250 255.255.255.0
interface Ethernet3
nameif DMZ-Database
security-level 100
ip address 10.154.42.250 255.255.255.0
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
passwd qNgaqi5tLET5t2io encrypted
ftp mode passive
same-security-traffic permit inter-interface
255.255.0.0
255.255.0.0
0 255.255.0.0
0 255.255.0.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu DMZ-Database 1500
mtu DMZ-App 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside
icmp permit any DMZ-Database
icmp permit any DMZ-App
asdm image flash:/asdm
no asdm history enable
arp timeout 14400
access-group outside in interface outside
access-group INSIDE in interface inside
access-group DMZ-2 in interface DMZ-Database
access-group DMZ-1 in interface DMZ-App
route outside 0.0.0.0 0.0.0.0 10.154.10.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 10.154.11.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
prompt hostname context
Cryptochecksum:7e3d13100e0bab468be7323ac1d13c29
: end
PIX-515# exit
Logoff
zroth Wed, 05/30/2007 - 02:08
nat with identifier 0 does not translate at
all.It is mostly used for IPSec tunnel LAN
to LAN (but not allways).It means that all
IP addresses defined with nat 0 are not translated to any interface.
Therefore in your configuration can not
translation work.
If you want translate,you must first define,
what to translate.For instance in your case
the command nat (inside) 1 10.154.11.100 255.255.255.255 translates this IP address
on the outside interface,and the translated IP address would be that of the outside interface.The same for other interfaces,where global ( ) 1 is configured.Beware,the nat 0 command has higher priority!!!It means,if you want to go to the addresses defined in access-list IN-OUT-NONAT,no translation comes into effect.
Hope it helps a little.
Zdenek
