Hots not actively polling
May 28th, 2007
I'm currently running CSA 5.1.0.69 agents, MC CSA V5.1 and a remote Database. The polling is failing so all hots have a status unknown. The interval polling is an hour.
Logs are included without problems and new host can be added aswell.
The error message is appear is:
[2007-05-29 08:59:54.486] [PID=4268] [webagent]: Db error occurred: Error: -2147217865 Msg: IDispatch error #3127 Description: [Microsoft][ODBC SQL Server Driver][SQL Server]Invalid object name 'csausuario.FindPlatformId'. SQL: DECLARE @platform VARCHAR(256) UPDATE host SET hostname = ?, description = ?, os = ?, os_version = ?, okena_system_type = ?, okena_version = ?, last_reported_rule_version = ?, last_reported_var_version = ?, last_downloaded_rule_version = ?, hint_sent_count = 0, @platform = ?, platform_id = case when platform = @platform then platform_id else
[2007-05-29 08:59:54.486] [PID=4268] [webagent]: Error code=2029 text= Error: -2147217865 Msg: IDispatch error #3127
Does anyone have the same problem? Any suggestion? Thank you.
lcuchisanmillan Tue, 05/29/2007 - 01:30
Finally i fixed it. The problem was that function/object (FindPlatformld) was associated to another user in teh database.
