05-29-2007 01:44 AM - edited 03-05-2019 04:20 PM
dear
I have cisco 50 switches & router.can you suggest any good software for manage switches & router.
05-29-2007 02:01 AM
HI Upendra, [Pls Rate if helps]
If my understanding of your question is not wrong, managing means Monitor:
MRTG http://oss.oetiker.ch/mrtg/ the best tool in Industry wide to Monitor the Switch Status, CPU, Interface, Traffic, etc.,
MRTG tool requires MRTG.exe, RRD, Apache, Perl for Working in Unix & Windows. For more details visit:
http://oss.oetiker.ch/mrtg/doc/index.en.html
Big Sister (in Unix):
Is also one of the Tool to Monitor all the Interface of Switch, CPU, Traffic, etc.,
Visit: http://bigsister.graeff.com/
Next, there are no other specific Third Party Software to Manage the Switches/Routers. Only "CISCO SDM" (Security Device Manager) - GUI based tool to Manage the Switches / Routers
PLS RATE / Vote if Helps
Best Regards,
Guru Prasad R
05-29-2007 03:18 AM
Upendra,
SDM is a freeloaded GUI tool for routers.You can buy Cisco LMS (Lan Managment System). This will manage your Lan switches and Routers.
http://www.cisco.com/en/US/products/sw/cscowork/ps2425/products_data_sheet0900aecd80532cf5.html
HTH,
-amit singh
05-29-2007 11:04 AM
Before purchasing LMS, make sure you can justify the expenditure. Also, if you've never used LMS it can initially cause more headaches than it's worth.
Get the eval before you buy!
05-29-2007 03:50 AM
HI Again,
If necessary you can buy "Cisco Works" LAN & MAN & WAN Management Suits.
Cisco Tool: CISCO WORKS
Pls Rate if Helps
Best Regards,
Guru Prasad R
