CTC displays Unknown#
May 29th, 2007
I have 2 ONS15454 connected as a ring. Previously, when I log in CTC it displays both nodes. But now when I login from any 1 of them, CTC only displays the directly logged in node and 2 DCC lines; the other displayed as Unknown#. I search docs and it says that "Node initializing for the first time".
What should I do to resolve this problem? I have already "Delete CTC cache", Reset TCC card, re-create DCC channel, both nodes use the same Username/Password and in the same subnet.
mcavalli Fri, 06/29/2007 - 01:17
  • Cisco Employee,
In this cases, it's correct to delete CTC cache and (if you can) reset TCC cards.
Some questions:
- Do nodes have same SW version?
- How do tou reset TCC cards and re-created DCC, via TL1 or via CTC on node that you can reach?
- Both nodes are connected into same LAN?
hatv Thu, 10/11/2007 - 09:45
You must to have a management network which operate parallel with data network. It mean, yours LAN ports on the both TCC card can ping each other. So, when you can manage two ONS node.
Cheers.
rick.king Thu, 10/18/2007 - 04:41
How was the DCC communicating? OSPF, Proxy? Was Proxy potentially turned on and someone disabled it?
