Solution for (9) point-to-point data T1's
May 29th, 2007
I have a customer which wants to replace his (9) Cisco 1720 routers with just one router capable of handling (9) point-to-point T1 lines. Is the Cisco 2811 capable of this and what might the configuration look like? Thanks...
overturf Tue, 05/29/2007 - 05:57
Thanks for the reply...what combination of HWIC, WIC, VIC, or VWIC type modules would I use to configure the 2811 for (12) T1's?
Paolo Bevilacqua Tue, 05/29/2007 - 05:57
Even a 2801 can do up to 16 T1's nowadays. It would use 4 x HWIC-4T cards. But better would be to use a router with T1 interface to avoid the external V.35 converter. In that case the best density is onthe 7200, with the PA-MC-8T1. Also ask your telco if they support channelized T3 that would allow you to terminate all the T1's with a single physical interface.
