documents for Cisco Unity
May 29th, 2007
I used Cisco unity 4.0 for a client, and i need to edit a document of exploitation or howto for unity.
i need some example for administration and configuration with screenshots.
thank you for help.
Zin.Karzazi Tue, 05/29/2007 - 06:18
  • Silver, 250 points or more
A screenshot documentation wont help you a lot if you are going to administer Unity. I suggest buying some books (Unity fundamental, Cisco Callamanager and Unity: step by step) these are really good books to start with, then use the Search function of cisco.com and look for Unity administration/Configuration..etc. Last but not Least the Cisco Netpro forum, if you have questions regarding Unity post them and you will get help :)
Karzazi
