ASA - LU Allocate Failed Messages
May 29th, 2007
I recently did a quick check on one of the daily logs on my ASA 5520, and I noticed that fairly often I am getting an "LU allocate connection failed". I obviously checked the error message on the site and it says "Stateful Failover cannot allocate a new connection on the Standby unit. This may be caused by little or no RAM memory available within the PIX Firewall.
Recommended Action Check the available memory using the show mem command to make sure the PIX Firewall has free memory in the system. If there is no available memory, add more physical memory to the PIX Firewall."
A little background info, I have 2 ASAs in an Active/Standby setup, the active Unit's log is giving the LU allocate failed messages.
Anyone have any suggestions? I did a "show mem" on my active unit and it was fine, not even using 25%... could it be the Standby Unit is having issues?
Thanks in advance,
Chris
conversyschris Tue, 05/29/2007 - 05:34
Result of the command: "show ver"
Cisco Adaptive Security Appliance Software Version 7.0(6)
Device Manager Version 5.0(6)
Compiled on Tue 22-Aug-06 13:22 by builders
System image file is "disk0:/asa706-k8.bin"
Config file at boot was "startup-config"
ConversysASA1 up 140 days 21 hours
failover cluster up 140 days 21 hours
Hardware: ASA5520, 512 MB RAM, CPU Pentium 4 Celeron 2000 MHz
Internal ATA Compact Flash, 64MB
BIOS Flash AT49LW080 @ 0xffe00000, 1024KB
This platform has a Base license.
conversyschris Wed, 05/30/2007 - 10:51
Here is my show ver, any advice would be appreciated.
Thanks JP,
Chris
conversyschris Tue, 06/05/2007 - 05:12
bump - sorry to bump this up the list, but if anyone knows whats going on, I would appreciate some advice. I logged into the standby unit yesterday (through asdm) and check the live log, I saw plenty of the same LU Allocation Failed messages over and over. I also did a memory check on the unit, and it was only using 20%.
Chris
serotonin888 Mon, 08/06/2007 - 05:57
Hi Chris,
I have the same thing on a pair of asa5520's. Lots of LU allocate connection failed messages on the standby.
Configured in Active\Standby running 7.2(2).
I only noticed the errors by chance so im not sure how long they have been there.
Memoey also looks ok with 80% free.
Did you ever find a solution or identify the cause?
Cheers
Andy
nickgoldwater Thu, 02/28/2008 - 14:31
I too see these errors but have not found a cause. Perhaps keeping this thread alive will help.
hhth12345 Mon, 04/28/2008 - 07:06
I too have the same problem on PIX 515E's 7.2(2)
