ISDN Dial-up howto?
Greetings,
I have an 1841 router eith a WIC-1B-U V2 card installed and not yet configued. The router also holds 2 WAN Ethernet connections through its FastEthernet ports Fa0/0 and Fa0/1.
I need to know where to start to have the following configuration:
-Test the ability of the ISDN WIC to initiate a dial up connection
-Bring up the ISDN connection
-Force the ISDN connection down
In the final configuration state, I need to have the 1841 periodically dial out (on a fixed schedule) whenever the Fa0/0 and Fa/01 ports are no longer carrying traffic.
Can anyone offer any guidance/help?
Paolo Bevilacqua Tue, 05/29/2007 - 05:55
  • Hall of Fame,
    Founding Member
If you never configured cisco and this is your first assignment, all this can take quite a time for you to learn, apply and test the configuration. The alternative would have a qualified person do that for you.
What do you have on the other side on the ethernet? To which router would you be calling with ISDN ?
These questions to point you in the right direction for configuration.
