ACS LDAP without cetificates
aksoyilker
We are deploying ACS4.1 for our campus and wonder if we can use LDAP as external database while using username/password not certificates as user access configuration.
thanks
Jagdeep Gambhir
Level 10
Level 10
Hi ,
What kind of authentication you will use ? You can use it with user name password but that is subject to the type of authentication.
we want to use peap ms-chap v2, but type is less important, is there any kind that uses name/password with ldap?
thanks
