05-29-2007 06:45 AM
Dear all,
I am trying to use the the Cisco Security Manager, v. 3.0.1 via client and try to make
the following action on an IDSSM Vers. 5.1(4):
Configuration Archive->Add->"Feth New version From Device"
But unfortunately I got an error Popup saying "FETCO OPERATION FAILED, configuration
fetch failed due to device communication service error"
The popup says to check vmsbesvcs.log and vmssharedsvcs.log.
Here follows the content of the 2nd file (the first seems have nothing related to
current connection attempt):
29-mag-2007 14:25:05.468,[ERROR],(DeviceCommunicator.java:196),Exception
thrown!,com.cisco.nm.vms.dcs.DeviceCommunicator,com.cisco.nm.vms.configarchive.FetchAn
dArchiveDeviceConfigJob@1722ad7-1180439655750.20
java.io.IOException: Ssh2Exception: com.cisco.nm.vms.dcs.ssh2.ssh2.ChannelException:
close() called twice
at com.cisco.nm.vms.dcs.ssh.SSHv2Impl.closeSession(SSHv2Impl.java:94)
at
com.cisco.nm.vms.dcs.DeviceCommunicator.closeSession(DeviceCommunicator.java:193)
at com.cisco.nm.vms.dcs.BaseDevice.closeDeviceSession(BaseDevice.java:449)
at
com.cisco.nm.vms.dcs.IOSDeviceStates.closeDeviceSession(IOSDeviceStates.java:552)
at
com.cisco.nm.vms.dcs.IOSDeviceImpl.uploadConfiguration(IOSDeviceImpl.java:422)
at com.cisco.nm.vms.dcs.IOSDevice.uploadConfiguration(IOSDevice.java:228)
at com.cisco.nm.vms.dcs.BaseProvider.uploadDeviceConfig(BaseProvider.java:355)
at
com.cisco.nm.vms.gdcs.DeviceConfigurationBase.uploadDeviceConfig(DeviceConfigurationBa
se.java:124)
at com.cisco.nm.vms.gdcs.GdcsUploadJob.performTask(GdcsUploadJob.java:61)
at com.cisco.nm.vms.gdcs.GdcsJob.perform(GdcsJob.java:171)
at
com.cisco.nm.vms.gdcs.GenericDcsWorker.processRequest(GenericDcsWorker.java:223)
at com.cisco.nm.vms.gdcs.GenericDcs.uploadConfigs(GenericDcs.java:84)
at com.cisco.nm.vms.gdcs.GenericDcs.uploadDeviceConfigs(GenericDcs.java:70)
at
com.cisco.nm.vms.gdcs.GdcsServiceImpl.getRunningConfig(GdcsServiceImpl.java:104)
at
com.cisco.nm.vms.configarchive.FetchAndArchiveDeviceConfigJob.perform(FetchAndArchiveD
eviceConfigJob.java:99)
at
com.cisco.nm.vms.task.dist.WorkerImpl.jobPerformWrapper(WorkerImpl.java:1405)
at com.cisco.nm.vms.task.dist.WorkerImpl.access$100(WorkerImpl.java:31)
at
com.cisco.nm.vms.task.dist.WorkerImpl$JobExecutionTask.run(WorkerImpl.java:1536)
at com.cisco.nm.vms.task.dist.TaskThread.run(TaskThread.java:36)
We have entered primary credentials and enable credentials on DCR.
Does anybody know what it could be ?
Thanks.
Leorob
06-04-2007 08:23 AM
The error message should indicate that TLS enable changed
Please click following URL:
