05-29-2007 07:03 AM - edited 03-03-2019 05:11 PM
Hi guys i have a question.......what is the best way to limit your bandwisth to your customer......we are service provider and we have different customers i m pasting a config of one of them please tell me is it the right way to limit the traffic or there is better way to limit the traffic.....plus explain a lil bit how we calculate the formula (it referes to the two rate limit line) how we put numbers in that....Kindly see the attachment....thanks a million
05-29-2007 08:47 PM
Those 3 values are "Configured Rate, Normal Burst and Externded Burst".
This is how cisco recommend to configure those values
normal burst = configured rate * (1 byte)/(8 bits) * 1.5 seconds
extended burst = 2 * normal burst
Load interval command controls when input/output data will be loaded for calculation, default value is 5 minutes so yours is set to 30 seconds which means you will have more current stats when you run show interface command.
Hope it helps
Muhammad
05-30-2007 12:15 AM
hi,
Muhammed has stated it right, but i tend to have Normal Burst = Externded Burst in order for the traffic to be firmly policed to the desired rate.
HTH, please do rate all helpful,
Mohammed Mahmoud.
