Drops on ASA 5505 ver 7.2(2)
May 29th, 2007
We have a customer with an ASA 5505, which is dropping packets on the outside interface. The output from the "show interface" indicates Switch ingress policy drops.
show int e0/0
Interface Ethernet0/0 "", is up, line protocol is up
Hardware is 88E6095, BW 100 Mbps
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
Available but not configured via nameif
MAC address 001a.e2ef.f201, MTU not set
IP address unassigned
277059685 packets input, 74460445394 bytes, 0 no buffer
Received 44 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 L2 decode drops
17179909933 switch ingress policy drops
23266211 packets output, 7912969026 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
0 rate limit drops
0 switch egress policy drops
Has anyone seen this before, as i cannot find any information on the CCO to troubleshoot this issue
c.walsh Tue, 05/29/2007 - 08:10
I have looked at this, but the nameif command is used on the vlan int & the vlan is up. The ASA is connected to a router, so i can't see tagged traffic hitting the interface?
tsalon Wed, 06/13/2007 - 09:37
Hey Everyone,
I am karim
I am using firewall asa5540 7(2).2 and I can see several and continious packet dropped on all interfaces. My asa's are connected usingauto/auto to switches cisco 2950 also using auto/auto.
Can anyone help?
