No it is not the same as a crossover, a rollover cable would be laid out like this:
End 1
Orange/White, Orange, Green/White, Blue, Blue/White, Green, Brown/White, Brown
End 2 is the inverse of End 1
Brown, Brown/White, Green, Blue/White, Blue,
Green/White, Orange, Orange/White
So however you wire one end you just do the opposite on the other. Very Simple.
JORGE RODRIGUEZ Tue, 05/29/2007 - 10:17
  • Green, 3000 points or more
Thank you all for your reply and information.
Just made one and it worked ..
Rgds
Jorge
