CM User Defined Group mempership not stable
May 29th, 2007
I have LMS 2.6 with CM 4.0.6,I create 5 user defined group,I am facing unstability problems, sometimes I go to CM topology I didn't found any device in this groups, I return back to CM group admin,then I edit the group I found the devices then I click finish then everything work fine.
The last problem I face it was now the user defined group has the all discovered devices not only the memper devices.
Any advice
Thanks in advance
Joe Clarke Tue, 05/29/2007 - 10:06
Debugging grouping problems can be tricky since it is not very easy to enable debugging. However, you can check the CampusOGSServer.log when you are experiencing a problem with the membership computation to see if there are any associated errors. If not, it may be best to open a TAC service request so that they can guide you through enabling and disabling OGS debugging.
