Route traffic based on the PORT #
May 29th, 2007
Hello all,
I need to setup a rule on a router. Any SMTP traffic destined for a certain I.P address must route traffic to a certain address. The Ip Route command can route traffic based on source and destination I.P addressing, but how can I filter this traffic based on port 25 (smtp)?
Overall Rating: 4.5 (4 ratings)
mohammedmahmoud Tue, 05/29/2007 - 10:55
You can do PBR (Policy Based Routing), as it is the only mean of source based routing, kindly check the following links and please do come back if you have further questions:
Policy-Based Routing
http://www.cisco.com/warp/public/732/Tech/plicy_wp.htm
Configuring Policy-Based Routing
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfpbr.htm
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
danny9797 Tue, 05/29/2007 - 13:06
thank you both.
sry, I got confused with something when I mentioned the source routing
mohammedmahmoud Tue, 05/29/2007 - 13:09
Hi Dan,
You are very welcomed, please do come back if you have further questions.
BR,
Mohammed Mahmoud.
