Help Uninstall VPN Client
May 29th, 2007
I basically cannot get online without the VPN Client installed (even if it is not running). I am trying to uninstall the Cisco VPN Client v5.0 on my PC (running WinXP Pro SP2). When I uninstall it, I restart my computer. When my computer is finished rebooting, I can no longer access anything online. I cannot use my MSN Messenger; I cannot get to any websites; however, I can pull an IP Add from DHCP. Can someone please tell me what I can do to solve this problem. The reason for uninstalling is because my company VPN program (Nortel-based) will NOT function with the Cisco VPN Client installed.
drolemc Mon, 06/04/2007 - 08:51
  • Silver, 250 points or more
I think that after uninstalling the VPN client you should ask your service provider for the default config required to get the access and check if everything is fine. Other way would be to remove the VPN client in safe mode this will ensure healthy removal of the product.
Kamal Malhotra Mon, 06/04/2007 - 09:15
  • Cisco Employee,
Please try to ping something on the internet with the IP address e.g. 4.2.2.2
If that works then it could be a DNS issue and you can hardcode the DNS server in the adapter settings.
If you are not able to ping anything even with the IP address then you need to check if there is any firewall on the computer that might be preventing it. Please run a registry cleaner to ensure that there are no traces of the Cisco VPN client on the system.
HTH,
Please rate if it helps,
Kamal
